Bracket for powersupply to fit ?
topslop1
This is not the best picture but as you can see my power supply doesn't stretch to the entire case. I need some kind of a power supply adapter bracket to get it to fit correct? Does anyone know what I need and where to get it?
http://www.flickr.com/photos/30828638@N06/3750062742/
Thanks - and if you don't have a clue of what I'm talking about look and see that there are two screws on the right side and none on the left. I'm afraid to stand the case up and down with just two screws in on one side.
what case is that? it look like it's not ATX spec.
EDIT: are you sure you didn't put the screws through one of the vent holes and thus shifting the PSU up and over where it doesn't reach?
The case came with a bracket to mount the PSU to.
Where's the old PSU? I bet the bracket is still attached to the old PSU.
It's literally a graveyard of parts around here. I didn't shift it over, it's just not big enough to mount across the back. And there was no old psu, I got the case from a friend who moved. I think its ATX spec, no?
Yup as others said you are missing an adapter plate between the PSU and the case. Probably still on the old PSU or in the trash...
