BQT P6 PRO - 850 W ???
game14
Anyone knows where to get this PSU - be quiet BQT P6 PRO 850 W ???
I googled it but didnt get any results for here in USA . :(
It's made by Listan, and it's more htan likely EU only. Mostly because of the 220v input.
I'd try something else here. HX 620, maybe.
Actually it's rated for 100-240V so it'd be fine here if you could find one. Although it's a Topower and you'd be better served to find a nice little PSU by just about any other manufacturer and settle down and have a passel of fun.
The Thermaltake Toughpower 850 would suit your power needs (actually a smaller PSU would most likely) although I have no idea of your aesthetic needs.
what i found most interesting about it is the size !!! other PSU over 600 W r usually very big and wont fit a SFF case .
I have the NZXT that's based on the same platform and it is no smaller than the X3 or the Tt Toughpower 850W.
Under different branding, yes it is. The new NZXT's (850W and 1KW) are the same thing only slightly different on a cosmetic scale. Same goes for the BFG 1KW. It's a Topower build, nothing all that fantastic.
