Hey I just bought the new Danger Den DDC-12V
Is is possible that this pump actually goes to fast? What I mean is I bled my system, and have NO air in the lines... It runs fine with no bubbles/air for about 1/2 and hour then bubbles start to form coming out of the pump on the out flow side, first they are small but then they get bigger, I have NO leaks in my system, the level actually goes up, I assume because of the added air..
Does this pump agitate the liquid so much that it CREATES bubbles in my system, if I turned the comp off for a while the bubbles will dissapate and the fluid level goes back to normal, so i know I am not losing fluid, I thought maybe I had a small leak, just enough to let some air in, but the fluid level never changes...
If I slowed the pump down would it help stop these bubbles??
and Next question is.... The pump I bought came with a molex connector, AND it came with a BLUE wire attached to a female 3 pin fan connector..... THIS setup is not ont he DD site, nor is it in ANY of the reviews for the pump.... WHAT is this blue wire for???????
