Bought Colorometer, now what?
briancl
I bought the Spyder2express colorometer, and I've installed the latest version and run it. The different is the image is a tad bit darker and I think I might have lost some of my black. For example, on this test image page, I can't see any of the boxes labeled 1-4.
Is the calibration not spot on? Are my settings off? I have an LG 246 LCD, and I set the "CSM" to sRGB and the brightness to 20 and then ran the spyder software. At the end, when I did the switch to show the before and after, the only difference I noticed was the slightly darker picture.
I also downloaded colorimetre hcfr software, but I don't really know what to do with it. I copied the dll over and was able to take a reading using 10 levels of grey, but beyond that, I have no idea what anything means. Can I use this software to tweak/enhance my profile? Or can I use it to verify what has been set?
Also, is there any for me to use this sensor and software to calibrate my LCD TV? I know there are differences between a computer monitor and TV monitor, but is this sensor better than my eye for setting the basic settings on my TV?
Honestly...the software that comes with the Express package is kinda crappy. I now use Coloreyes Display pro with my Spyder 2 and get great results. There is a way to calibrate tv's with the Spyder colorimeter but it involves using 3rd party software and making your own test pattern dvd. I haven't tried it..
So you "aquired" the Spyder 2 pro software and then used that with the spyder2 express hardware. Good idea. :D
Are you talking to me or the OP? CHS and CDP aren't the Spyder 2 pro software or even made by Colorvision. Incidentally I did "acquire" the Spyder 2 pro software at one time but the CDP software still gave me better results so I decided to purchase that..
edit- to the OP....I tried Colormetre HCFR also and couldn't figure out what the hell was going on...French mixed with poorly translated english didn't work for me. :(
