bought audio cd online...can't convert 'cause encrypted.
Harkamus
I bought Holly Brook's cd online in the digital format. WMA to be exact. It seems there is encryption so I can't convert it to a wav. I want to convert the files to wavs so I can burn them on a cd and listen to the songs in my car. I've tried a few programs so far to no avail. Is there any wma to wav converter that can bypass the encryption?
For what it's worth: http://www.hollybrookmusic.com/
Basically had to use a program that "recorded" songs from windows media player. You could select what format to save as. The recording aspect dropped the encryption. I used tunebite.
Had a thread earlier regarding this same sorta problem. I had BSB CD Never Gone June last year. Thanks to Autopray, sucker installed a damn "system device driver" and hid itself so that I couldn't find out what was corrupting the damn music.
I found and removed the offending DLL file, then proceeded to extract the CD using ISO buster, then burned to a regular CD.
