I finally decided to move up from cheapo wired keyboards to a nice Logitech Wave from this thread in the Hot Deals section.
Everything worked right out of the box, even without the SetPoint software installed.
Opened up Borderlands and loaded my character and I couldn't move; none of the keys on the keyboard worked. They would work for a few seconds right after I turned the keyboard on via the switch on the bottom but would then stop working a few seconds later.
Ok, I'll replace the batteries even though the ones that came with it where supposed to be brand new. Nope, same issues.
Installed the latest 64bit SetPoint software via Logitechs website and still nothing.
Same thing with L4D and I'm assuming Batman but I didn't actually try that.
PC is the main rig in my sig. Why wouldn't this brand new keyboard work in games yet be perfectly fine to type on?
