bought a dremel
Gibroni
i jut got a dremel. i've been wanting one for a while and finally broke down. can you guys give me some tips on the best way to cut a window out of a side panel what bits to use and such. I got the high power corded model. the 400 xpr. I had to get a new powersupply for my pc. i have an antec sonata case. so i got a thermaltake purepower 480 with the led fan on the bottom. but the fan guard hits the edges of the case becasue the stock ps had just the one fan on the back. so tht's why i finally bought a dremel. i might paint the inside of my case too as long as it's open.
