bennetvu said:You're right that I didn't provide enough info so here's a lil bit more.
He checked all the connections and it was properly connected. He swapped out my antec 350 psu and replace it with his. He told me after that, the fan start spinning so he turned it off. Now he's heading to Frys to get a new PSU to test it since his was a 20pin and my motherboard requried a 24 pin.
I'm sorry but I'm familar with PSU but how do you jump start the PSU without plug it in?quadnad said:have you tried jump starting the original PSU without it plugged in to the components?
bennetvu said:I'm sorry but I'm familar with PSU but how do you jump start the PSU without plug it in?
quadnad said:Leave the psu unplugged, then with a paper clip short pins 14 and 15 . Then plug the psu into the wall, and turn it on.
To be less specific, short the green lead to any of the black leads. Your PSU may need slight load to power on (plug a molex into a DVDRW or something)
