Bought 2TB - Need Help with Space Calculation
craige4u
Hello,
I just got 2TB HDD and a few confusion:
1] In order to get one partition of 50GB I allocated 51200MB… but after format it turned out to be 49.9GB only. The calculation above is correct as I used this before and I never got it wrong. (NOTE: 100MB windows partition is already created separately.)
In order to solve this I havd tried 51250MB, then it shows full 50GB.. Whts wrong here? is it related to sum new 4K sector as mentioned in the link below?
2] Another partition I created of 1.77TB and it shows 1.76TB free, whole 1GB less ?
3] Can u pls calculate and tellme tht If u combine both partitions, am I getting full capacity of a 2TB HDD after format? I am not able to add properly, I guess poor maths !
Link to my HD: http://www.seagate.com/www/en-au/products/desktops/barracuda_hard_drives/
Thx
You are getting around the correct size of 1.86 TiB. What is lost is that windows uses TiB but calls it TB.
http://hardforum.com/showthread.php?t=1347640
http://www.tomshardware.com/reviews/hitachi-7k1000-terabyte-hard-drive,1584-2.html
Partitioning is I believe is on 2048 sector boundaries. I believe you are seeing that combined with round off.
