Sorry for the silly noob question but I'm just getting around to upgrading my PC after a few years of neglecting it. I purchased a case (Cooler Master RC-922M) with a bottom mount PSU (Antec BP550 Plus 550W) but I want to make sure I'm installing the PSU correctly. The case instructions state the PSU can be mounted either way for optimal thermal performance but I have no idea what's optimal. Do I want the fan on the bottom of the PSU pointing up and blowing the air into the case (I'd assume not as this seems like it would just add heat to the system)? Or, do I mount the PSU with the fan on the bottom and blowing outside the case? I assume the latter is correct but worry because the case is going to be sitting on a carpet floor. The case does have feet that will raise it about a half inch off the floor, but is this enough?
