When I had my Thermaltake Shark case, I was air cooling my 8800gts cards.. I went with bigger fans (120mm) and it really helped keep my temps down!
yeah that design is awesome to keep vga coolbut half of it would get deflected by my raid card and all the cables i have down there
im installing a fan in the bottom of my case and was wondering which way it should be blowing for best cooling....
blowing out seems to be the thing to do, but just want to make sure
is your video card bent?
Isnt that video card fan blowing hot air towards the bottom?
yeah a port like that... erm well kinda.. not hacked to bits and infused in some demonic design.... just you know a regular port like from a regular side panel... something with screw-holes for the modest
