bottleneck? AMD 3500+ 2.2, 6800GS?
bubbaaaaaa
I keep reading about "bottleneck". I think I understand it....vid card is more powerful then cpu when it comes to games? Will I see any "bottleneck" if I slap in a 6800GS with my eMachine 3500+ 2.2? Maybe I'm just confused heh but will it work? PSU isn't a problem I have an antec around here somewhere or I can buy a new one. I just wanna play RTS and afew RPG games. Maybe check out afew FPS. Meh.
you should be fine as long as the eMachines has a PCI-E slot and I'm sure you'll have to use that Antec PSU if you got it.
If you have PCI-E slot and decent power supply, you wont have any problems and nothing will be bottlenecking.
I recently recommended this upgrade to a friend of mine with a similar machine and it's running very nicely.
I've got the exact same layout expect have an enermax PSU and asus sli. Works perfectly :)
hey man .. just be glad you're not still running a socket A setup like me ;)
