Why would you put the Texture Quality on High Performance but then put the AA on 16x? Also that 7900gs is going to slow to a crawl in most modern games with 16x AA.You should be fine ...When you set up you card in control panel try these menu tweaks ..You wont be disapointed
set all options
Antisotropic-Filtering 16x or highest#
Antialiasing-Setting 16x or highest#
Antialiasing Mode to (ON )or overide apllication
Antialiasing Transperancy------Multisampling
Comformant texture clamp-----Use Hardware
ExtesionLimit ----------------------Off
ForceMipMaps---------------------Off
Multi Display----------------------Single display performance mode
TextureFiltering-Anisotropic sample optimization---------ON
Texture Filtering-Negative LOD bios----------------------------Clamp
Texture Filtering Quality---------------------------------------High Performance
Texture Filtering-Trilinear Optimization-------------------------ON
Tripple Buffer-------------------------------------------------------------Off
Vsync------------------------------------------------------------------------Force Off
These Settings apply to 7900GS and 7950Gt provides fastest game response Adjust the ANISOTROPIC and ANTIALIASING slightly lower the Higher you go on your screen sizes past 1280x1024 75hz or 60hz --Higher hz is faster if your display will let you raise it..
16x aa would be a slideshow in some games even at 1280x1024. It doesnt make sense that you would overkill on the AA but suggest running games on "high performance" instead of "quality" or "high quality".Try it right now if ya dont believe me as i said The higher you go in Res to lower AA and Anisotropic filtering Ive already Run both cards on a21"widescreen ....Im not joking
What is the point of trying to run that much AA on a card like the 7900gs to begin with?Thats why you lower in game setting and have you Card set to run everything optimal try it if you dont believe me....Some Systems differ but most will benifit from this...I only have a few thousand hours of gaming so i wouldnt know .
Im sorry but you are not making any sense to me. Running 16x aa on a card like 7900gs just doesnt make sense either no matter what other settings you are using. If you want more fps then why turn aa on at all?Not trying to argue a point ....Lots of games run smoother with card adjusted high and the in game settings set slightly lower ...If your option are never enabled in the card you will never beable to use those options in the games you play ...Do you see where im comming from..
well i forgot to mention , i aalreadt bought the 7900GS.
i wanna know if i need to upgrade anything , or not.
thank you
You will probably need a better PSU.
Bah, 24a SHOULD do it
