Both onboard ethernet controllers constantly disconnect me
Bop
On my DFI motherboard both my Marvell and nVidia ethernet controllers disconnect me in the middle of a game of BF2, while all my other computers stay connected(friends come over to LAN).
I've reformatted windows, fiddled with options like change autonegotiation to full 100T, checksum offload and a few other things but nothing helps. I don't have enough room for a PCI card either.
I don't know what to do now... : /
Have you tried contacting DFI support? It's possible they may RMA the board or help you solve the issue.
I'm not sure what to look for in the event viewer but I didn't see anything that stood out.
As for an RMA... this is my 2nd board(SATA ports died the first time) so if I would have to send it back again I would just get an ABIT AN8-SLI instead of getting another DFI.
I'm going to check and see if it is the port on my router so I'll switch it from the first port. Now to do some testing.
EDIT: Nope I still get disconnected, I checked the event viewer after that to see if I could find anything but nothing occured at the time of the disconnect. I'm out of ideas here.
EDIT: It happens with a PCI Linksys card... wtf is going on here?! Looks like its not a motherboard ethernet issue. What could it be?
