Borked System. Help me find out why?
RanceJustice
Hello all. I've been having grief with the system in my sig. Let me list a few of the problems.
1. Biggest issue - Sometimes, when I turn on the PC as soon as I get into windows (after typing password, windows sound etc) the system instantly resets. Sometimes this is accompanied by crackling from the speakers, sometimes its not. Usually after it rebooted itself it would boot into windows normally. Tonight however, it has rebooted itself 5 times in a row, and continues to do so even after turning the damn thing off for a little while. Essentially, the box is now unusable as long as this continues.
2. Smaller issue - sometimes when the box is cold and has been left alone for a long time, it will not even POST successfully. That is to say, nothing will show up on the screen. If my motherboard beeps after pressing the power button, I know its going to boot fine. If it doesn't, I know it won't and have to turn it manually off and back on a few times until I get my "beep"
3. Smaller issue - semi-frequent yet unpredicable freezing in games. Sometimes, I'll be able to play for hours with not so much as a glich. Other times, it will freeze every few minutes. Not sure if this is related to the other two.
I've already replaced my power supply, RMAing an old (bad) enermax liberty that I thought was causing the problem. Now of course, I have a new Liberty that could very well be bad too? What should I chase here? At first I was thinking heat but boot time problems are rarely heat related. Right now the best theory that I have is that this Liberty has also gone bad. Does anyone have some theories? Thanks.
This certainly sounds like a power related issue. However, it may not be your PS. This could be attributed to one of your devices pulling way too much power and causing the computer to freak out. Personally, I would try removing all the non-essential components from the system and attempting to boot a barebones system to see if that resolved the problem.
You could also have a short in the case. Try removing everything from the case and firing it up on a non-conductive surface.
Also, try loading a live version of Linux to eliminate the possibility that this is OS/Driver related. Knoppix or Unbutu should work just fine for the test.
It also wouldn't hurt to give MemTest86 a 24 hour run just to test the mem.
If all else fails, try swapping that PS again with a friends known good unit.
