BORG COSMOS II
ASPHIAX
Hi All,
Been a while since I posted here! I started a thread called the 2001 - A Case Modyssey but that has been put on hold due to several problems and setbacks.
Anyway you people might have seen my previous systems:
USS EURISKO - Intrepid Mark II Class
Star Wars : IMPERIAL AT-AT
Here is my new build !
Its my personal system this time that is getting a facelift !
BORG COSMOS II
And back to Star Trek, my first love ! My favorite badguys were always the BORG. Half man / Half machine, NO merci, Adaptive shields and a killer one liner : RESISTANCE IS FUTILE !!!
here are some pics that i used for inspiration.
Man that case is big ! I just love the quality and design of the COSMOS II
I have got some idea's but nothings fixed on this one. No sponsors again so no rules , just having fun and thinking it all up as we go!
Now to post some work pics
Let me know what you think !
OK, I am not going to bore you with taking apart a Cosmos II. That has been captured so many times now !
My plan was to put 2 x 480 radiator in the bottom of the case. But the PSU was posing a problem. I was planning on making a false bottom to house it but the i stumbled upon Vandalo's BRILLIANT idea! This is so much more stylish and completely takes away all the problems I had. I think we will see this configuration many more times! (I only think its fair to credit him with the link to his work here ) Only thing I did was to place a additional layer of plexi for some bling !
I was able to squize a couple of 480 rads out of the budget. Also the John Lund reservoirs just stuck in my mind from the first day i saw them over 2 years ago. I just had to wait for the right project to come along to use them !
On to the next job. I want to continue the green UV reactive plexi line I created with the PSU. So after a couple of hours of sawing filing and sanding it was ready !
Here I lit up the plexi with a front cathode. The idea is to cover it up with a vinyl sticker and place a UV led strip underneath.
Placed both the radiators and made a couple of coverplates. Again a lot of sawing and filing but Aluminukm is such a great material to work with!
Perspective ..
To place the SSD's I use the bending bench to work a piece of alu. Fits beautifully !
Cause I am paying for it all and not using any sponsors, i had to take out the UD7 and 2600k out of the EURISKO. Still pretty good hardware and with this cooling power It will clock nicely !
HA , that is why I NEVER throw anything away (to my wife's delight!) I had to find a way to cover up the fittings of the reservoirs. That's where the pile of old HDD platters come in.
And sometimes you just have to be a little lucky. How is this for a perfect fit?
Just a quick couple of shots with a large UV cathode.
Also was able to score a third 580 gtx and a old line EKWB block. Just have to think on something for the SLI bridge that sticks out like a sore thumb
On to the next job, placing the UV led strip underneath the front grill of the COSMOS.
Just had to slightly dremel the inside to make it wedge a little and keep it into place!
Placed the Antec proquiet fans on the 480's
Sticker Time !!!
And that was it for this update !
More to come soon !
LOVE IT! I have followed your previous builds, but this takes the cake for me as a huge Next Gen fan. Really awesome man (I wish I was that lucky when it came to fitting parts :( ) Cannot wait to see more.
This looks awesome. Also, love the pic of your daughter and the box. :D I bet she just wanted to play with the box.
Thanks man ! Theres a plan for a whole cube sticking out of the side of the Cosmos!
Thansk! Yeah she could have played hide and go seek with it! She would fit into the box!
Here is another update from the work I have so far !
For the 2 x 480 rads in the bottom I need more air into the case. The front will have a 120mm fan pulling freshair in from the front and I cut a whole into the bottom so the 8 x 120mm fans on the rads can suck clean air in from the bottom.
I also received the vinyl BORG logo sticker and cut a piece of UV reactive to the right size.
I cut the SSD holes into the plexi and placed a piece of alu behind it.
I already have 2 x 90Gb in Raid 0 for max performance and am looking to score a 240 for storage.
This needs a lot of detail filing but I will not bother you with it !
I will hook up the led strips to an arduino so I can adjust the light strength. Way to bright now!
The BORG logo for in the door.
That was it for today !
Laters!
