I installedd Bootskin on my own computer and have had no issues. I installed it on a buddies and he cannot seem to import any skins. After going to the import option and opening up the folder (already unzipped).. nothing appears. I manually type in the bootskin.ini to see if it will open and it says...There was an error important the skin file. Possible causes are a currupt skin file, or a read only skin directory. I checked the folders attributes and find it is a read only directory. I try to remove the read only attribute and apply only find that it wont remove the attritube. He is set up as an admin.. any ideas?
