So I am sure most of you have heard of this problem. It is pretty common and I have seen it on many laptops during my IT positions. If you have not seen this error, basically after turning on your computer with windows 7 or vista installed it will post and you will see a error saying...
"BOOTMGR IS MISSING
CTRL-ALT-DELETE TO RESTART"
From what I understand this can mean many things but most of the time it means that some boot file within your windows os is corrupt? Anyways, I had the pleasure of receiving this error today. I am currently posting this from the computer in my sig, which is the one that received this error. I have temporarily bypassed the problem but it is not a complete fix and I was hoping you guys would be able to help me find a solution.
I have three hard drives in this computer. Two Intel X-25M G2 80 GB SSD drives and 1 WD Caviar Black 640 GB drive. The two SSDs are not in any raid configuration, they are just separate drives. The Windows 7 OS is on the C: drive which is one of the SSDs. The other SSD is just a storage drive for games and the WD Caviar Black is just a storage drive for media.
After a bit of tinkering I was able to bypass the problem by only having my C: drive plugged into a sata port. I then tried it with both the SSDs and it booted fine again. I then tried it with only the C: drive and the WD Caviar Black and it did not boot. From this deduction process I think it is safe to conclude that the problem has something to do with the WD Caviar Black.
After getting into windows with both the SSDs connected before posting I connected my WD Caviar Black back into the sata port and it appears to be working fine. But, as soon as I restart the error will appear again unless I unplug the WD Caviar Black before posting.
Any suggestions on how I might further diagnose this?
Thank you
"BOOTMGR IS MISSING
Thank you
