Booting Problems.
Otacon
Hey I just got all my new parts to my gaming pc yesterday and I finished putting it together this morning. Here are the specs to give you a rundown.
8800GTX
E6850
Asus P5K Intel P35 mobo
Antec 900
PCI Wireless adapter
2GB GSkill HZ's
Tuniq Tower 120
DVD burner/writer
320GB HDD
Corsair 620HX
Ok so I made sure all the connections were in place, all the CPU fans were connected, The GTX and the 24Pin in the mobo was in. I plugged it all in and turned it on. It did boot up and launch BIOS. But I forgot to plug in a Keyboard or mouse. Both my keyboard and mouse are USB so I turned the machine off and repluged them in. When I tried to start it up a 2nd time, nothing would happen. Not one thing would start up at all. Keep in mind I did shut the PC off myself before I plugged in my mouse and keyboard.
When I started it up the first time I didn't press delete to go into BIOS so it just went to the screen that said to load the OS. It did make one BIOS beep which meant it detected everything. But now whenever I press the power it just doesn't do anything. when the PSU switch is on the Mobo LED just constantly beep over and over. I Assume this means its in sleep mode.
Hope you guys had some exp with this before. Only thing I can think what i didn't completely get was when I installed my Tuniq Tower there was 2 plugs comming from it. The 3-prong plug that I plugged into the CPU fan port on my motherboard, then some really small black chord that I didn't plug into anything.
Wasn't too sure where to post this. But any help is appriciated.
Sry if I dont respond fast, but I'll have very limited internet access till Sunday.
