Booting problems IS7-E (Beep of death)
Morazl
Here are my specs:
2.4c
1024 Corsair XMS PC3200
5900 128mb
Seagate 80gb SATA
Samsung 60gb 5400
Lite On 52x32x52x
SB Audigy 2
Zalman 400watt Silent PSU
HSF SLK900U
Just the other day I was switching my ram from single channel to dual channel, because I noticed it was in there in single-channel mode. After that, I put it all back together, worked fine... started playing WoW and noticed it was a bit laggy, sure enough only 512 was recognized, the stick of ram wasn't all the way in... (dumb me) but it wasn't hot or anything, no burning smells anywhere in the case... So i make sure it's all the way in there... and while i'm doing that I accidently knock off the CMOS jumper.. (woops) I put that back on in the correct place (looked it up in the manual just to be sure). I turn it on to boot my monitor just sits in standby mode and i get the long beep of death...
I ruled out PSU, RAM, Video, tried booting with just ram and video... The only thing I can think of, is having a dead processor... or would it at least get into the bios with a dead processor?
Another thing is I have a clear acrylic case, which I guess shouldn't matter too much...
I air-dusted it all out this morning hoping for some luck, but none...
If anyone could just reply with some sort of help, it would be greatly appreciated, ABIT is no help to me for now :(
You couldn't boot without the CPU installed, and if the mobo doesn't think there's a CPU there, it's going to bark at you. I'd reinstall it just to be sure before throwing in the towel.
Thanks for the quick response
I lifted the HSF off the cpu, took it out, inspected, put it back in and strapped it back down... still the same results.. i'm really convinced it's somethign with the motherboard, i've looked through the whole manual on signs like this but nothing is listed of course :/
first thing is to clear the cmos (with the jumper) and start fresh. Second, try booting with just the original stick of ram. If that works, switch the two sticks, still only using one to boot. Run memtest on both. Somtimes if one stick has errors you won't notice it until you try running in dual mode. You can also check the bios for the latency timings and try loosening them a bit.
I'll try that with the RAM, but I can't even get anything on my screen, no post, no nothing.. I hope this works...
no post even? I didn't read that part. Dead Mobo's definitely the likely problem. Do you have a second system you could try switching out with?
I tried every combination in every dimm, and i tried two brand new sticks of corsair.. still the beep of death.
Remove the CMOS battery for 30 mins then put it back in and try powering up.
i have a brand new system here also but im building it for a friend... different socket cpu, pci-e ... can't really do much with that.. as far as testing goes.
okay... I took out the battery for 30 mins and booted with the same results unforunately.. i guess im SOL?
I tested my processor in a friends computer.. it worked flawlessly, along with my ram...
it's definately the motherboard.. I guess i'll try to RMA it unless anyone else has any more suggestions?
