Booting Issues
Kazz
Ok, I'm currently building a second computer from old parts, and I am having one major issue with booting up at the moment. And it seems that I have exhasted most - if not all - possiblities as to what I think it could be.
Basically the HDD i have doesnt have an operating system on it, and it has been formatted etc. I have a Win98 + Drivers boot floopy that I want to run at start up and I have changed the boot sequence accordingly in BIOS (Floopy->CDDrive->HDD) Insert the floopy (which I have test on this computer and works perfectly) and booted the system up.
This is what happens:
- I start up the computer and it goes through it's regular RAM test and identifies all the components I have attatched like normal (Floopy, HDD, CD-ROM, etc.)
- It then loads the PCI Listing table, as soon as it finishes listing the last element (ACPI Device) it reads the floopy disc for around 10 seconds then just idles. If i press a key on the keyboard, it reads the floopy for another 10 seconds and idles.
- I have tested different floopy drives - same result.
- I've tested a CD boot disc and changed the boot sequence accordingly - same result.
- When i use a HDD that has an OS installed it says "Windows did not successfully start up last time it was started blah blah - load in safe mode, safe mode etc. etc." If I choose any safe mode options it loads some drivers but freezes half way through. If I choose normal mode, it freezes the computer.
- I've tried different RAM, Video cards, HDDs, Floopy drives, CD drives - same result.
- I've bought new IDE cables - same result.
Anyone have the faintest idea what is going on? Any help would be greatly appreciated.
The system is an Athlon TBird 1.4GHz, on a Shuttle Mobo with 256MB DDR RAM, GF2 MX400 -- and with that said i have a P2-400 (separate computer) which also does similar things on start up.
one floppy disk cant hold an entire operating system. Are you sure its not the disk designed to help windows that is already installed boot up? if it is, you're not going to get anywhere using it. You need a cd to fully install it.
Try running by here and picking up a 98 boot disk. Put it on a different floppy disk and try to boot to it and see what happens.
My guess is that it is missing some of the boot files that it should have.
Cheers.
