booting from CD
roberttran
Hey,
I am trying to install gentoo on my xserve but i have trouble getting the live cd to boot. I put the cd in and hold the c key but it still goes into mac os x. Then when i went into mac os x, the OS sees the cd and its content. I was messing around and i think i told it to do a network boot. Now when the system starts up, it has that network symbol flashing and nothing happens. What should I do?
Thanks,
Robert
You can hold ALT at bootup for a "Boot Manger" kind of thing, it detects all bootable media, Network, Local, FireWire, USB, and CD-ROM. (Floppy is Applicable)
Given its at least G4, not sure about anything newer?
if it is not recognized as a bootable CD by the system it will boot to HD...if you hold option at boot you will go into the startup manager and if the disk shows then it is recognized as bootable and you can select it
Aye, well on the Apple Keyboard its says Option bigger I suppose I should have said that..
Yes, the only way it will show, is if the CD is actually bootable, but it's an OSX Install CD, so I assumed it was bootable.
not to slam you or anything Gunter...but if you read roberttran's post he is trying to install gentoo and not OS X
Thanks!
I've been trying both the C key and ESC key but didn't think to try the ALT key.
-Robert
Ahh well, What is Gentoo? :confused:
I must of read it quickly and thought he was trying to install OSX, but whatever Gentoo is, Option seemed to work. :cool:
