booting from an external dvd drive
K Scott
i just recently bought an external dvd burner to burn a bootable disc. i know that this boots fine because i tested it on a computer that has an internal dvd drive and it worked fine. my computer has no internal dvd drive, so i have to us ethe xternal one. the problem is, it will not let me boot form this. i think its because it is a usb device and my bios doesnt let me boot form usb. is there any way to get around this? or do i need to update my bios or soemthing like that?
If your BIOS does not support booting from a USB device, you are probably out of luck. You can try a BIOS upgrade, but if the rig is in your sig, I wouldnt hold my breath. I'm not knocking HP, but they do not tend to add features.
Try enabling "Boot other devices" in the BIOS if you have such an option.
Also try hitting ESC at the POST screen and see if you get a boot menu that will let you choose the device.
