I have a WD raptor drive that I want to install in an older system. The board doesn't have sata ports, so I went and bought a pci sata controller card. It turned out to be a RAID card as well. I put in the card and the drive, and all is well. The card and the drive are detected and I can see the files I have in the raptor drive. I have two other drives in the system. They are both pata drives of course. One is used as a data only drive, and the other is partitioned into two partitions. One partition has windows xp and the other has windows vista. What I want to do is to get rid of the two OS's and do a fresh xp install on the raptor drive.
It should be easy, but there is something I want to make sure of. When I boot using winxp cd, will the raptor drive be detected?
The windows copy I have is slipstreamed with sp2.
Thanks.
Thanks.
