Booting an ISO image from a remote PC
rotteneggz
[H]ello all,
Here is my problem: I need to boot an ISO image from windows that is stored at a local PC using a remote computer. I will have the image somewhere in the computer.
After the computer boots using the ISO image by restarting the pc, I'd need to go through the prompts in order to complete my task.
I have a few questions regarding this.
Is it even possible?
I heard of Grub, a program that would let me boot a program/os remotely. But if i restart the PC, won't i lose the remote connection?
Therefor i wont be able to enter in the commands i need in dos.
Can anyone help?
Btw the "program" i am refering to is DBAN. So what i am saying is i want the ability to wipe my HDD clean from a remote location, possible?
Thanks in advance
I suppose there is no one you could coordinate with on the remote system to physically boot and launch DBAN? You may want to look into the enterprise version of DBAN called EBAN.
Uhh, wouldn't it be easier to boot from CD/USB/Floppy? :confused:
maybe some sort of TFTP boot would be possible?
What exactly is TFTP and would i allow me to use Dos after i restart the PC?
Negative, i need to be able to do this at a remote location by myself.
So let's say i set the BIOS up so it boots from floppy while having the DBAN floppy in. So i restart the computer remotely and then what? would i lose control over the PC? would i lose the remote control of the pc?
check if your BIOS supports network booting
Will do and i will report back
I think i've figured it out. All i need to have it automatically erase the HDD is to modify the syslinux.cfg file (http://sourceforge.net/forum/forum.php?thread_id=1577365&forum_id=208932). Now all i need is to be able to load the ISO automatically while the pc reboots. I could do this with a floppy disk or cd rom but i think i'll try to figure it out useing GRUB instead of useing a physical disk. Thanks for the info everyone.
