bootable f@h cd?
R
ring.of.steel
Guest
do any of these exist? would install suse but i have no dvds and cant find the other ones i had. i am looking for a bootable linux cd that goes straight into f@h, also it should not have a performance impact over the linux client.
Yes, there are available :
-SMP client bootable live cd, without the extra stuff : http://reilly.homeip.net/folding/cd64.html
-Console client bootable live cd, without the extra stuff : http://reilly.homeip.net/folding/cd.html
The neat thing with those links is that you can enter your folding name and team id then it will create a custom ISO with this so just burn it then boot it to fold. The only negative is no ability to save the steps unless you setup a TFTP server (there are HOWTO for both Windows and Linux in http://reilly.homeip.net/folding/).
The other way is with foldix, created by our own folder unhappy_mage : http://www.hardforum.com/showthread.php?t=964162
a) The Linux client IS only 64 bit. For 32-bit you need the Windows SMP client, and Windows (obviously) isn't live-bootable.
b) Dual Athlon MP's won't make deadlines on SMP WU's. Sorry, but an X2 3600+ or Pentium-D is the absolute bare minimum.
Cool! Good links!
Anybody know of anything similar for running the SMP client off a USB stick? I saw the USB stick setup here http://reilly.homeip.net/folding/usb.html but that just appears to run multiple instances of the single CPU client.
Cool! Good links!
Try emailing the author of this and ask if it is possible to make a bootable smp usb stick. I would love to see one myself for temp borging of machines in the bench.
Well, couldn't find an e-mail, but I PMed him on TR and asked about it. I'll update with what info I get back.
Here's the scoop on USB SMP from notfred...
"Hi Parja,
I'm updating the whole diskless folding suite at the moment and one of the things will be a new USB folding stick that will run both single core or SMP depending on what the processor is capable of. It's probably going to be at least another month until I get it done though, too busy with other non-computing stuff."
so i should install windows and then use 2 seperate console clients?
thanks
How does this SMP client compare to say a Windows SMP with regards to PPD?
I'd venture to imagine the 64-bit Linux one would be faster than the 32-bit Windows one. Of course, I have no data to back that up, just experience with both. :)
