boot up problem
Bigern822
when my system is booting up, I get message
conflict I/O : 3F8
Press F1 to continue
Any help will be appreciated, thank you
Check your serial port (COM port) settings in the motherboard BIOS. Sounds like you may have accidentially set both ports to the same address or accidentially set the parallel (printer) port to the same address.
If you don't use the serial ports on your computer I'd recommend disabling them.
