Boot to PATA drive on GigaRAID controller?
DoWSB
I have a Gigabyte 965P-DS3 (r.3.3).
I have two SATA 250Gig drives in RAID 0 on the GigaRAID controller as my main drive.
(and also a DVD drive on the single IDE controlled by the GigaRAID controller)
A couple of days ago, it ceased to boot into windows due to a "missing or corrupt" file.
I want to retrieve, and backup, my data before a clean format and reinstall of XP.
So, I temporarily detached my two RAID 0 drives.
I then attached an old 13Gig PATA drive to the single IDE (as slave, the DVD is master).
I loaded WinXP onto the 13Gig drive. It boots fine, and everything works great.
My plan was to reattach the two RAID 0 drives, boot the the 13Gig PATA drive, and gain access to the data on my SATA RAID so I can back it all up.
BUT, no matter what I've tried, I cannot get the 13Gig PATA drive to be the boot drive WHILE the two RAID 0 drives are attached.
It just keeps trying to boot to the corrupted WinXP on the RAID 0 drives.
1. I've tried setting the PATA drive to master, and detaching the DVD drive, and it still tries to boot to the RAID
2. I've looked in BIOS to change the boot device, the only thing pertaining to booting to the hard drive is the choice "hard drive", not RAID or PATA or IDE
3. I've looked in the RAID BIOS for options on setting the boot drive. nothing.
4. I've booted to a boot floppy, run fdisk, and tried to change active partitions, it informs the that only "drive 1", the RAID drive, can only be active, "drive 2" can not. (regardless of whether the PATA drive is master or slave)(and I can't swap places since the RAID is SATA and the 13Gig is PATA)
5. I've checked the RAID drives to see if I could set them to slave. apparently master/slave is not something you can set on SATA drives.
6. (and of course I've tried Safe Mode, but it won't boot to that either)
Again, it boots fine to the PATA drive while the RAID drives are not attached.
What can I do to boot to the PATA drive WHILE the RAID drives are attached?
Ok. Problem solved.
I had severe tunnel vision while choosing the Boot Device in BIOS.
Yes, it's true that you can only specify "hard drive" in the Boot Device selection,
BUT, right above that, is the "hard drive preference" where you can choose which hard drive to boot from.
Man I need to get out of the Socket 7/A mode of thinking.
It now requires two selections to be made in BIOS to specify which drive to boot from, not one (at least on this board). Seven years is too long to wait between upgrades!
Oh well.
