Boot problem
I have a problem with a computer that I built for my brother yesterday. The thing is that yesterday it was working fine, my bro was able to install Windows XP and do other stuff on the computer but today he took off an USB cable and now the computer starts but then shuts down in less than 2 seconds. The motherboard is a 4CoreDual-VSTA, it has a 3.4 P4 CPU and 2GB of RAM.
Can anyone tell me what could be causing this problem and how can I fix it?
PS. I asked my brother what happened and he said that he just moved the case and took off a USB cable and that it was working perfectly last night, the last time he used it.
Are you crashing as windows loads or at the Bios boot.
If you are crashing at the Windows boot up then it could be alot tougher to figure out.
If you can't even load in to bios then it should be pretty simple to figure out.
Make sure all your cables are still secure.
Check the video card and memory make sure it's secure.
If you have multiple sticks of RAM try booting them one at a time, if you only have one try moving to new slot.
If none of that works unplug all of your drives and try to boot the system with only the video card and memory.
Also make sure your CPU fan is plugged in tight a lot of mobos won't even boot if it's not. Also if the CPU fan has a manual fan controller turn it up as well.
