Ur_Mom
- May 15, 2006
I have a new Sandy Bridge setup that is giving me some serious problems. I can't boot. At all. The fans start up for ~2-3 seconds then power off. Then on again. This repeats indefinitely. Can't get into BIOS. No beeps. Nothing.
What I've done so far:
Cleared CMOS.
Tried board outside of case with minimal components.
Tried different RAM.
Tried another board (same make and model).
Checked CPU in a different PC, works fine.
Heatsink is seated correctly, reapplied thermal paste, etc...
The ONLY thing I haven't done was try a different PSU. I'm using an OCZ 700w model that utilizes the 8 pin 12V plug and the 24 pin ATX plug. The PSU works great in a Core2Duo machine I have right now with everything plugged in. I figured if it was a power problem, it would show when I didn't have anything plugged into PSU vs. a full load.
I've Googled this, and it seems like a common problem, but no solution. Some it's the PSU, others it's something else... I'm stumped. Anyone have a similar problem? Any suggestions? If I replace the PSU, any recommendations on a sub-$100 GOOD PSU?
Cleared CMOS.
