Boot issues on Gigabyte Z68 UD5
night_2004
I am hoping that someone might know how to fix this. We just finished a move (hardware failure or damage?) and when I set my rig up it refuses to boot if the motherboard BIOS are set to RAID. If I boot with ACHI (non-RAID) the system comes up fine (though every drive I had on RAID1 now shows up twice). But if I enable RAID in BIOS I get the error that there was a disk boot failure.
System Specs
Seasonic X750 PSU
Gigabyte Z68 UD5 (B3) + i7 2600k
GTX 680
Crucial M4 (OS) + 2TB WD Green + RAID1 1TB WD Green + RAID1 1TB WD Black
Steps Taken
Reset CMOS by pulling coin cell (backup BIOS failed a checksum when this happened?)
Pulled all drives except for the SSD/OS drive, left RAID enabled, problem persists.
Reseated all SATA cables on the drives and on the motherboard.
Reseated all power cables on the drives.
Moved the SSD to another SATA3 port.
Moved the SSD to another SATA2 port.
Reflashed BIOS with the same version (F10)
The only other steps I can take are (1) reinstall Windows which is a last resort, (2) put my SSD into my wife's i5 + Z68 UD3 and see if the problem persists, (3) replace the SSD which seems pointles since it boots in ACHI mode, or (4) replace the motherboard.
Another fun note is that if I boot in ACHI to Windows it will often ask me to insert a disk into the optical drive. Uh, no.
There's got to be something I am missing. Any ideas?
you could check your hard drive boot order to make sure your OS RAID is still set before any other hard drives / raids.
Checked and verified that the M4 is the first on the list. Also disabled any other non-HDD boot options and I'm still seeing the same thing. I'm about to set up a USB drive as a Windows installer just to see if the drive can be seen with RAID enabled.
Hmmm...latest tidbit of information from the Windows 7 installer (trying to verify the SSD at least is viable).
"Windows cannot be installed to this disk. This computer's hardware may not support booting to this disk. Ensure that the disk's controller is enabled in the computer's BIOS menu."
That's a new one.
Having dug through the BIOS and disabling the eSATA controller (Marvell 88SE9128) everything started working. I have no clue why those two settings are related unless there is a boot ordering setting I am not seeing in BIOS.
