This isn't so much a problem as a nagging frustration with the motherboard. When I try and boot I get a steady underscore which holds for a period of about a minute, followed by a "5A" which appears in the bottom right corner of the screen which also holds for about 30 seconds to a minute, followed by a rapid boot of the operating system.
Intel Quick Resume (VIIV) has been disabled, and the SATA drive is set to IDE per the recommendations which came with the board for running non-VIIV setups. I looked on the website for slow boot problems, and it told me to enable Quick Boot, but I'm not sure where that setting is located in the BIOS (searched, couldn't find).
The BIOS is BIOS update 1577 (downloaded and updated from Intel, unfortunately the problem persisted).
Anyone have a possible solution?
