Boot Camp installation problem
Arti
I have a MacBook and I'm trying to install Boot Camp. You've probably heard of the problem where people can't press Enter on the installation screen because they have peripherals attached, but I'm getting the same problem and I have nothing plugged in at all. And if I manually reboot the computer, it goes straight to the Windows install and I can't figure out how to abort it or eject the disc. Essentially, I'm forced into an install process that I can't get through and I can't try another disc because I can't get this one out. Advice, anyone?
i think you can hold the mouse button down while it's booting and the disc will eject. additionally, you could hold the "Option" key down while it's booting and that will bring up the boot select screen. you can then use the eject button from there.
gracias. now time to try it with a different copy of windoze
make sure the version of windows you are using has service pack 2. If it doesnt you can use a program like nLite to slipstream service pack 2 and burn a new copy.
