Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I have an HP laptop penitum 4, and the level of the audio output is very low and I was wondering if there are any programs (free or buy) that will increase the output level.
Did it come with any EQ software for whatever onboard solution it uses? If so look in there or try and crank it up as high as possible in your control panel settings. Thats the only two things i can think of.
If all your volume controls are already up then anything else you do in software is just going to cause clipping and it will all sound like shit. This sounds like more of a hardware problem than a software problem.
