a bong cooling question? wtf...potheads should stay away from electonic parts for fear of bong water shorting things out....
i dont understand the question. are you trying to syphon out the water? what the hell are you talking about?
umm yeah you tard
A Bong cooler: http://en.wikipedia.org/wiki/Bong_cooler
I posted a reply in this thread... or was it your other thread that you opened by accident?
Eh, either way, I said "go for it" just make sure the tube you're using isn't cooler than the evaporated water... You don't want any condensation on the tube.
yeah i posted in the wrong forum.... just wanted a few more opinions before i go drilling holes in my walls![]()
How humid is your climate? If you vented it outside with a plastic tube you could get great temperatures... provided it's dry out.
It doesn't matter what its like outside, the air he will be forcing through the bong cooler is inside air. He simply wants to baffle the exhaust air outside.
I say go for it, however I am worried that a hose, depending on length, might significantly reduce your airflow. Try blowing through a long straw, then cut it in half and blow again. There should be no problem with piping the air outside so long as you have enough air movement.
for some reason im seeing dryer vent hose in your future.. well regardless of what type you use i think you could get around the possible flow problems by running an extra fan at the exaust end of the hose just to keep things moving..
the only other thing you might look out for is what side of the house you put it on, if the wind hits the side of your house where the vent comes out, it could stall airflow, or even reverse it.. if your water level is high enought this would mean sending water back out your air intake (thought it should never really be that high, reverse pressure's can do wierd stuff)
What would really be nice with a bong cooler would be to somehow route the air thru a condenser and recyle the condensed water back into the bong as part of a closed loop system.
This would solve the the major disadvantage of a bong cooler (water evaporation), if possible/feasible.
At least it would be a "neat" mod to try...
Yea, the evaporation is the issue. Unless you could put a water-level sensor in the resirvoir hooked to a valve on a water supply to automatically keep it filled. Of course it would need some good filtration to eliminate the minerals/etc from the system. Hmm....thinking a tap like on my icemaker - salvage a sensor from an auto in the junkyard (washer fluid) - just gotta work out the valve setup.![]()
