Bong cooler question
qdubbs
Can i seal the Top of the Bong and have a hose go thru the wall into the bathroom or the balcony. So all the moisture goes out and not in my room? Would that work? Im thinking it would actually perform better...
EDIT: Dammit i was pretty sure im in the water cooling section :eek:
Should work :) Make sure the tube is big enough, and not colder than the moisture or else you'll get condensation in the tube.
