Bois not detecting primary Ide hard drive??
urbanlegend786
hey, i was supposed ot go get xp pro today but i am going to the amusment park woth my friend later on today so i cant but i have a linspire iso file sitting at home and when i ws trying to install it on my new Dfi system the bois doesnt detect any hard drive and when i try to boot from CD it says "DISK BOOT error, insert...and i forgot the rest but yeah can anyone help me out with thsi problem.....it doesnt detect my ultra ata hard drive((WD 160 gb)), then i went into the bois to check it out and then i saw it said i had no hard drive and ihave my hard drive the primary ide hard drive????????
system specs are in my sig
i would appreciate all the help i can get
WD drives require no jumper setting when it is the only device on the IDE channel. My guess is you have it jumpered to Master and that is what is causing the problems.
thanks i would pprecaite some more opoinions too, hw do i change the jumper settings in the manual it doesnt show which is the drive jumper
Agreed. WD's have a "single" drive setting. By setting to master it looks for a slave device to be attached. If that device isn't there, it'll cause problems.
You can get jumper settings from the WD website. IIRC, you won't use any jumpers at all, but don't hold me to that.
thanks fo all the help guys, so if i connect a dvd drive to my slave connecter wont have thsi problem and anyone have a link to that part of the WD site???
It should have a diagram on the drive what the jumpers should be. I'm dis-inclined to say it's an issue with it being jumpered to master though. I've always set my drives to master when they were the only drive, or one of two drives on the cable and never had a problem with that. The only problems I've seen are with cable select. Western digital, seagate, ibm, hitachi, never had a problem with it being jumpered master.
Just out of curiosity, did you crack the system open to check cables, power, ide, etc, just to make sure?
thanks blackrino and all of you other guys who helped me out ...i fixed it and now i am gonna install the drivers and sownload hl2 and i'm gonna play some mother freakin games
