Boinc, seti and windows XP, high priority start help needed
elec999
I need help starting the seti@home and its C:\Documents and Settings\All Users\Application Data\BOINC\projects\setiathome.berkeley.edu\AK_v8_win_SSE3.exe in high priority mode on all my cores, all the times windows boot. I am not using this machine for anything else, just seti and more seti. I want my AK_v8_win_SSE3.exe to always run at high priority. Is there any simple way, scripts app, to achieve this.
Thank you
you dont need to set that stuff.. it automaticly does it for you.. the reason the priority is set so low is so that it doesnt lock up your windows due to it requiring some cpu cycles.. otherwise putting them on high priority may make windows unstable.. no matter what it will use the entire cpu.. if something needs the cpu it will give up some of the cycles to that program while it needs them..
When you have it running normally, now, are you losing time in Task Manager to other processes ?
