BOINC MilkyWay Nvidia Issue
plext0r
[H]ard DCOTM x3
I configured a GTX 660 yesterday on a Linux x64 host. The MilkyWay 1.02 opencl_nvidia tasks complete and are validated. Every Separation (Modified Fit) v1.28 task fails and I would like to know why. I notice the GPU is only running 1 task at a time at about 65% utilization. I then found and implemented the following app_config.xml and restarted boinc completely:
Code:
<app_config>
<app>
<name>milkyway</name>
<max_concurrent>2</max_concurrent>
<gpu_versions>
<gpu_usage>1.0</gpu_usage>
<cpu_usage>0.05</cpu_usage>
</gpu_versions>
</app>
<app>
<name>milkyway_separation__modified_fit</name>
<gpu_versions>
</gpu_versions>
</app>
</app_config>
The host in question is shown here:
http://milkyway.cs.rpi.edu/milkyway/results.php?hostid=567997
Thanks for any troubleshooting ideas. I would really appreciate it.
EDIT: I just clicked on some of the tasks at the above link and found the following:
Code:
<stderr_txt>
../../projects/milkyway.cs.rpi.edu_milkyway/milkyway_separation__modified_fit_1.28_x86_64-pc-linux-gnu__opencl_nvidia: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by ../../projects/milkyway.cs.rpi.edu_milkyway/milkyway_separation__modified_fit_1.28_x86_64-pc-linux-gnu__opencl_nvidia)
</stderr_txt>
I'm running on Red Hat Enterprise Linux 6 x86_64 and it appears its GLIBC is outdated for the Separation tasks, but works fine with the normal tasks. Doh!
Do you have both 32bit and 64bit libraries installed? Possibly just update them? I'm not a Linux guru, but have read a few posts in the past to make sure you have both installed if you want to be able to run 32bit on 64bit systems and had read that they made some changes once on the directories.
I'm actually making a drastic change. Wiping RHEL 6 and installing the Ubuntu 12.04.2 desktop release. :D This host was one of my RHEL 6 hold-outs and I think it's time it was migrated to Ubuntu.
Bout time :D
