BOINC GPU Projects without the CPU projects?
Status
Not open for further replies.
Jon855
[H]ard DCOTM January 2008
Is there any way to run only selected projects on the GPU if supported and to not have the CPU component to run for that particular project?
Nevermind, I found out that I can't do what I want to do specifically but you're able to only run GPU or Both GPU and CPU but not selectively selecting the projects to run on GPU instead of CPU and still have others on the CPU...
Oh hell. I suppose I'll just wait for another project in which the GPU are also supported :D
My ATi 5870 is sitting there humming along.
go on to the website of the boinc project.. go to your account settings and uncheck the cpu part.. you can force set it to only run gpu WU's..
then what ever else you have running on boinc will run on the CPU..
Oh thanks, didn't realize that...
:D Now my GPU will be kicking in ;)
Now I'm running Collatz Conjecture
Killing the thread. Thanks monkey.
Status
