Board will not post on a new build
la_guy
I just built myself a new machine using an Asus P8Z68-V Pro.
The board will power up but will never post. What happens is it powers up for 17 seconds then shuts down and reboots and stays on.
I get no hard drive activity and no USB ports work.
My system specs are again an Asus P8Z68-V Pro, Corsair 4GB Vengence ram, Core I5 2500K and an XFX 6950, Windows 7 64 bit.
Any suggestions would be gteatly appreciated.
disconnect everything except video, 2 sticks of ram, cpu/cooler
your ram was dual channel 1.5 v?
Use one RAM stick at a time, and try it in each slot. If it works, then you may have a memory problem. If it doesn't, you probably have a CPU or motherboard problem. Try clearing CMOS and disconnecting all unnecessary peripherals.
Are you sure the cooler is on properly? Overheat could do this.
I don't think it'll do the 'reboot and stay on' thing.
You're talking a double boot without anything actually happening on the second boot right? Couple of things to check or keep in mind:
1) Try booting with 1 stick of RAM, no video card (integrated video works on this board), no hard drives, no other peripherals unless absolutely needed for POST.
2) Check to make sure 8-pin EPS connector has firm connection, same with ATX 24-pin connector.
3) CPU put in the right orientation? Thinking you probably did that right since you aren't smoking the board. But with that 17 second double boot thing who knows.
4) A cooler mounted improperly would cause the computer to shutdown quickly because of out-of-control thermals, but I would think the computer would *stay* down. Nevertheless check that while you're checking the CPU installation.
5) Bad power supply probably wouldn't do this either. Did you have a working PC on it before?
6) ASUS, in my book, doesn't have the best quality or customer service. If none of the above work, return the board and get a new one. Do not just RMA for a refurb unit which takes so long to get to you that you can't return the board wherever you bought it.
Im only using 1 stick of Vengence ram.
The power supply is a Corsair HX 1000.
This was my first build so I could have screwed something up. I will try to disconnect everything and use the integrated graphics. I am using water cooling on an EK high flow block I used thermal paste and all. All parts are new except the power supply and hard drive.
What should happen on a successful boot?
I tried everything you all mentioned and still nothing. I chalked it up to I got a bad board.
Any other suggestions I will try but im looking to RMA.
Sounds like you've exhausted your options for now. RMA the board so that hopefully you can get another one and try it out before the return period ends for the purchase. Or just return it and buy a new one (preferred option personally).
Is the board in a chassis?
FWIW, I always do a "pre-build" outside of the case. Might be worth going back to this step. Many times I will build the full system outside of the chassis and load the OS as well. Just makes things simpler if you end up in a diagnosis position later.
Just for reference.
When I build something new.
The set up should consist of the MB, cpu and stock cooler,one stick of RAM placed where the MB manufacturer recommends it be placed for one stick, and a video output. Done outside the case, on the cardboard box.
NO hard drive or peripherals, except the keyboard for the BIOS settings.
Remove the battery and reset the CMOS. Replace battery.
plug in the 24 and 8 pin PSU to MB.
turn on the PSU and then attempt to boot. Successful boot will take you to the splash screen and then the no drive detected screen.
Turn off, restart and then press delete to enter and set up BIOS.
