Nearly all s939 boards support s939 Opterons. Some might not recognize it properly out of the box, but a BIOS flash would fix that.sht said:very few boards support the opty but it will still work
you probably mean, very few boards officially support it, but will still run it without problems.sht said:very few boards support the opty but it will still work
Just go for the 3500LL PRO 2gig. when u get it you wont know how u lived without it.benamaster said:I like the Corsair 3500LL XMS RAM. It has the LED Activity lights and says right on the box that it works best on the Asus A8N32-SLI. I have never had a problem with Corsair. I'd say go for 2GB of RAM. It will probably cost you just shy of $300. If you're on a tigheter budget then go for G.Skill, Mushkin or OCZ they all have top of the line products that overclock well.
