Blutooth keyboad doesnt work until after login
DeadByDawn
I find my blutooth keyboard doesnt work until i login to my system.
Is there a way around this?
Thanks
FYI.
I am running vista 32 bit.
Login the first time after boot, or after the system is locked? You probably need the bluetooth driver/program loaded for the machine to enable it, and it starts after you log in.
Its actualy on bootup.
Its most likely what you described where the bluetooth drivers are not loaded until you start your session. It even takes a minute after login for the devices to begin working.
Is there a way around this (i.e such as having bluetooth startup as a windows service or something)
thanks
