Bluetooth Reciever
Jaxel
I have a PLANTRONICS Pulsar 590A Stereo Bluetooth Headset, but I dont have a bluetooth reciever on my computer. What would you guys recommend to rectify this? I've been looking on newegg for one, but I cant really find anything in the way of confirming whether or not it works with my headset. I'm looking for something small like a usb thumbdrive.
Most, if not all USB thumb drives should work. Do you know which profile the headset uses? If in doubt, find the one that supports the most profiles and it should work.
EDIT: http://www.newegg.com/Product/Product.aspx?Item=N82E16833156069 should work fine. The profile is A2DP
It is a no name brand, which should be fine, but I am sure most dongles will support this profile as it is pretty standard now.
