When I walk or run outdoors, I like to hold my phone in my hand as opposed to using an armband or something. And I just bought a bluetooth stereo headset to replace my wired headphones, the Jabra Sport.
Of course the first thing I do is pair it up with my Galaxy Nexus phone and go out for a walk to test them out. And I noticed every step I took, the audio would cut out. I was puzzled what was going on at first. So I come back and read the manual (things are bad when you have to read the manual) and see this...
"Bluetooth as a technology has limitations when used outdoors. For optimal reception, place mobile device above waist and on right side of body. Recommended placement is on your right arm."
It seems to explain why when I'm walking, the pumping motion of my arm causes the phone to move closer and further away from the headset and I guess in my hand it's on the edge of it's range.
It does say it has a 30 foot range indoors. I wonder why the range is so bad outdoors? I guess some diminishment is expected, but it's range is less than the length of my extended arm? Is this going to be a universal issue with any bluetooth headset or is this just not a good product for what I want?
