Bluetooth headset issues
daemitus
So I went and bought an aliph jawbone after reading some of the things about it. Works perfectly with skype, except when I try to use it with ventrilo, it seems to have heavy static and cuts in and out every second or so. I'm using a Cirago 3210 reciever, and the toshiba stack drivers that came with the cirago. I attempted to use the widcomm stack, but that didn't seem to change anything.
I'm hoping this is something simple that I can tackle after I'm done moving. Any ideas I can save for later when I've actually got the hardware to test them?
(actually, I've still got the stuff for a day or so, just need to unbox it for a good fix)
edit: xp sp2, onboard sound (ip35 pro). if that helps any.
