Bluetooth Audio and Bose wireless headsets...
Grimlaking
Has anyone tried these for computer gaming, and if so what did you think? Was the latency horrible?
I would try before buying. Bluetooth can have incredible latency, enough to destroy lipsync in movies and lag your sound in games.
Yea I've watched some netflix with bluetooth on my phone just fine. Dongle's arn't expensive and the headset sounds amazing. Will try for sure.
Ok here's the rub. If you are a multitasker when gaming don't bother. Bluetooth standard only plays one source type at a time. IE you can have your game audio. Or you can have the mono format for Discord. I wish my system would be smart enough to handle both but that is not the case.
Check out Audeze Mobius. Seems like a fantastic bluetooth headset for gaming or just listening to a movie.
I love the sound of this headset. That's not the problem. It's a limitation of bluetooth. IT's either audio codec or voice codec not both. So if you want to use discord AND game its wired or nothing.
