Blue Screen of DEATH while at default?!
Status
Not open for further replies.
Asazman
Well, my computer was up for like an hour, and when I tried to play some BF1942 I got a very brief blue screen (~.2 seconds) and then a restart. Tried to boot into windows, the second my desktop loaded, got another blue screen (this time ~2 seconds), and yet another restart. I'm pretty sure I can rule out heat....as I've got a Prometeia Mach I phase change. The BIOS is at default, but what else could it be? My mem is at default as well. Specs are in sig, thanks peoples!
make sure theres no condensation happening from the prometia.
if there is dont turn it back on untill you fixed it.
ok, crazy question. Is the cooling system running at spec? :)
Hmm.. what does booting into safe mode do?
you didnt hit 20k in 3dmark2k1 and your at 2.75ghz:eek:
maybe your CPU just isnt stable at that level?
if you can manage to boot it up again, run some prim95 to see if its a hardware problem, or maybe the hard drive you boot from is corrupted
how would i check for condensation?
As I said before, and as the title states, I am at DEFAULT! I am not at 2.75Ghz, I am at 2Ghz! Ahh!
Thanks peoples! Later tonight I will surly try running memtest, thanks again!
wait - is there any chance that my power supply is causing issues? I've got an Antec True480...I thought that would be more than enough. what do you guys think?
Originally posted by lopoetve
check the voltages. Strange things can happen.
looked in the BIOS, the voltages weren't too out there, looked about normal.
Hi, Im getting this exact same problem.
Anyone knows what it could be?
dont bump ancient threads -_- make a new one, with useful information... blue screens can be caused by any number of things...
well, I didnt find it like making more threads on the same subject was needed, when there was a perfectly fine one here.
On the other hand, I downgraded my ATI drivers and so far it seems to be working fine.
Further testing is needed.
Mod Edit - As has been pointed out, please don't bump three year old threads without a good reason. Your system may have similar issues, but the root cause may not be even close. If you want the best, quickest help for your system problems, post the specifics in a new thread. Thanks - BlindedByScience
well, upon further playing I still have the same problem. sucks
Status
