I go and install vista sp1 and then after it reconfigures everything and I get a blue screen. It says there was no hard drive found before windows started for some reason.
Is this a 64 bit version of windows vista that doesn't include service pack 1? If you hvae 4 GB or more memory installed, you can get BOSD like crazy. Remove all ram except 1 stick and try to install again.
BTW much more information is needed if you want to get much help including system configuartion etc.
