FoolOnTheHill
- Aug 2, 2001
Okay, I own a Lian-Li PC-65, which has a high-intensity blue LED installed as the stock power LED. I've been fine with it for a year or two, but recently, I've decided that it's just too bright, as it lights up my room at night. I plan on just putting a simple resistor in line with the LED to take down the brightness. Anyone tried something similar?
Basically, the things I want to know are:
-What voltage does the power LED run at?
-What value of resistor should I use for this mod to take down the brightness so that it's an indicator, not a beacon?
Thanks in advance
Thanks in advance
